Idiot lights....to listen or to ignore - Page 2
Started by Scott & Heather, June 14, 2015, 07:17:53 PM
I noticed about 12.8 volts going to the tail lamps, I assume that would
Be fine?
blue_goose
Did you read the voltage with the bulb out of the socket?
Jack
Yes...was that bad?
blue_goose
No that was good, I checked the voltage on my front turns with the bulb in and got 12 volts.  When I replaced it with a LED the LED melted with the 24 volts.  The 102C3 that I have has a resistor in line to drop the voltage.  The LED didn't put any load so no drop in voltage.
Jack
Ok. Got it. I think I'm ok then because it was 12 volts without the bulb in so it must be true 12 volts. I want to upgrade to LED rear lights so this is good to know
