Is this right? - Page 2
Welcome to BCM Community. Please login or sign up.
Shoutbox
Recent
Members
  • Total Members: 7,094
  • Latest: lupo704
Stats
  • Total Topics: 35,141
  • Online today: 674
  • Online ever: 72,743 (April 21, 2026, 08:33:54 AM)
Users Online
  • Users: 1
  • Guests: 461
  • Total: 462
  • Krash
461 Guests, 1 User
Krash
Is this right?
Started by Tikvah, October 20, 2014, 12:15:21 PM
50 wt becomes cement at sub freezing temps...
Dave5Cs
The point was Mike the guy used 30 w because he could not find 40w and people clouded up and rained down on him that was my point.
I know if it was my engine and I needed a couple of gals of oil and 15/40 or 30w was all that was available the old DD would need to acquire a taste for 15/40 or 30 w because that is what it would get.
Take Sean his Neo always ran at 200 degrees or a little above he never used 50W as the book calls for, the book is a guide line but you do what you have to do IMO
Ed Hackenbruch
Even though i had 40 wt with me, the shop wanted to use 30wt for the break-in of my engine for warranty purposes. Told me that once i got back to Yuma i could change it to 40 wt if i wanted to even though it would have less than 2000 miles on it.
All shops use 30w after a out of frame rebuild Ed and run it for 5000 miles and then pull a sample
Mike in GA
It is very helpful for members of this board to mention when sales of this nature are on.
    I just called O'Reilley's and ordered my three cases.
    Thanks for sharing the news!
Mike in GA
Past President, Southeast Bus Nuts. Busin' for almost 20 years in a 1985 MC 96a3 with DD 8v92 and a 5 speed Allison c/r.
HighTechRedneck
A little wear is an essential part of break-in.
Quote from: luvrbus on October 21, 2014, 06:20:45 AM
Quote from: Ed Hackenbruch on October 21, 2014, 06:11:48 AM
I don't know about your shop ED but Williams,United and Stewart and Stevenson use a 30 W with a high ash content like 1.27 for the break in period after a out of frame so do I
Geom
So on the subject of ideal oil pressure, what should we be looking for? What is an acceptable idle oil pressure reading?
1966 GM 4107
6v92 Turbo
V730
Ed Hackenbruch
Clifford, i am not going to change it yet....it only has 1625 miles on it now. Will pull an oil sample when i change it.
Geom, the book for my 5A says with the engine hot, 11 lbs minimum idling.
The 6V92 anything above 7 lbs is safe the turbo takes some of the oil pressure always check the idle rpm before checking the oil pressure and worrying about it takes away the stress off by 50 rpms makes a world of difference
