4104 Tires - Page 2
Welcome to BCM Community. Please login or sign up.
Shoutbox
Recent
Members
  • Total Members: 7,094
  • Latest: lupo704
Stats
  • Total Topics: 35,141
  • Online today: 674
  • Online ever: 72,743 (April 21, 2026, 08:33:54 AM)
Users Online
  • Users: 1
  • Guests: 455
  • Total: 456
  • Krash
455 Guests, 1 User
Krash
4104 Tires
Started by mung, September 19, 2014, 05:55:38 AM
There is no need to spend extra bucks for the G rated 16 ply tires the F rated 14 ply will last just as long on the little light weight 4104 I don't know about RPM seems like the 6-71 would like a smaller tire like the 500 rpm  ::) it needs all the help it can get
gene burge
I saw it somewhere on this forum that old / scrap school buses were a great source for tires , noticed 2 days ago 14 skoolies parked in lot in front of a local scrap yard , gotta go check it out !
1992 mci 102c 6v92
The metric size of the 11R-24.5 is the 285/75R-24.5-which is the same diameter as the 11R-22.5. Then the 295/75R-22.5 is smaller yet. If you don't need the weight carrying capability of the 12R-22.5, I'd stay with 11R-22.5. The RPM (revs per mile) of the tires are:
476rpm-11R-24.5
485rpm-12R-22.5
501rpm-275/80R-24.5 or 11R-22.5
517rpm-295/75R-22.5 or 275/80R-22.5
Good Luck, TomC
   Be careful on tire sizes on your coach. If you had 12:00Rx22.5 with 4:11 rear end ratio the top speed will be 69 mph@2200 rpm; 3:55 rear will equate to 79 mph@2200 rpm. 3:55 rear would be ok with 11:00Rx22.5 since you would lose about 3 to 4 mph top speed. With 4:11's you may want to go to a 24.5 rim with 1100's or 295's to keep your top speed. Since you don't want to run against the governor cruising, figure on 5 to 7 mph less for economical cruising. When you start pounding out the miles against the governor, that's when the oil starts leaking from all the less than perfect gaskets and seals, and other issues.
mung
How fast will it go with 22's and spinners?
Anyway, Eagle, thanks, I will check St. Lucy battery and Tire.  They have a good rep around here.
Vern in Central Florida
PD-4104-772
Dave5Cs
Last month put on 11 X 22.5 G rated 14 ply, Toyo's 6 for $2,786.00 with truck balancing, tax 8.00, mounting, CA tire fee and disposal fee. They ride very smooth.
mung
There is a St. Lucy Tire and Battery about 30 min South of me, so I will see what kind of deal they will offer me.
PD-4104-772
Watch what you buy I read the ad I am thinking that is a trailer tire you can use on the steer axle
I'm running XZE2 Michelin steers and R227 Bridgestone every where else...they are all position, I would assume that any steer tire would be suited to the drives...but I know less about tires than I should...
I never saw trailer tires used on the drive but I will ask a friend that is VP for Toyo of the southwest
Quote from: luvrbus on September 19, 2014, 12:22:39 PM
Toyo is a good tire I would expect to pay over 500 bucks each for M127 16 ply Toyo
[/color]
Clifford, I just looked up what you suggested....after looking at Toyo's web site the M127 is probably not even made anymore.
maybe the M177 was what you mean.... the M127 (if they even have it, the web site might be as out of date as I am..)... ???
These are their current trailer tires available:
http://toyotires.com/tbr/tires/trailer-position-tires
Price of tires today is crazy I paid 1200 bucks in Aug for 4 Toyo A22 for a Lexus SUV and the guy said he was giving me a buy ???
Beesme
Can anyone tell me how many revs per mile with 315/80 r22.5 thanx
Bruce E.        62 pd4106 vs730.
Gonic N.H.
   Michelin XZA2- 315x80x22.5 is 492 per mile. Other brands or models may be a couple of rpm more or less. I assume this is with new tread. About 29 engine rpm faster.
