? ID Hydraulic clutch line - Page 2
Started by robertglines1, October 17, 2012, 06:49:42 PM
While the fluid is nominally non-compressible, the larger the line size particularly with a rubber hose or even teflon lined, the more you can get expansion that feels like compression.  Smaller lines just feel firmer with brakes, guys like Mario Andretti can feel it, I can't...  For a clutch it just doesn't matter, the pressures are too low to expand almost any hose but you need the volume for a clutch.
robertglines1
It's in!!! Braided stainless steel flex lines on engine/clutch end .  Adjustable push rod between slave cyl and clutch arm. Checked stroke and is right on. Life is good.   Bob
Bottom
Bottom2
