Massive gook buildup on brake drum
Started by Buffalo SpaceShip, November 09, 2006, 03:16:09 PM
Len Silva
I'm sure we all have our horror stories.  In my case I had rigged up leveling valves on my 4104.  I knew I just had to get a little ways under it to remove the drain plug on the aux fuel tank....I'll just air it up, won't take but a minute.
I hooked up my compressor, set to about 90 psi and walked away for a few minutes.
POW!  blew the left front bag.
I'll never be sure if I would have gone under the bus without blocking it, but I was thinking about it.
Len
Quote from: Buffalo SpaceShip on November 15, 2006, 08:00:08 AM
That time, just like last night, I was happy to be relatively spry and skinny. Of course, a larger man would probably work smarter under a bus. Or never go under there in the first place.
bb
Brian now you know why I love my "pit" so much as us larger guys have trouble even getting under a bus, let alone move faasstt while under it! LOL although back when I were about 4 or 5 pants sizes smaller (and I didn't have a pit)I was under a 102A3 working on a bad brake chamber. What I didn't realize was that one of the hired hands (who was working on an $ income job) didn't realize I had the air hooked to the bus for a reason and took the air hose to use where he was working! I didn't get crushed , but there was some yell'n goin' on and they scrambled to get air hooked to the bus before leaving for lunch before I could get out from under the bus! I got even as I was the Boss and assigned who did what ! And that same bus needed a new valve on a full holding tank as the one on there was seized up, and well one good turn deserves another!  BK  ;D
FloridaCliff
Brian,
First of all, GLAD your OK.  :o
And Thanks for having the GUTS to share so that others may learn and live. 8)
Hopefully your on the downhill side of all this mess.
This has been one heck of a trip for you Pal. :P
Cliff
Mark Twain
Buffalo SpaceShip
Quote from: FloridaCracker on November 15, 2006, 11:02:00 AM
Agreed! But, no fires in the bedroom! Yet...  :P
I think this last round of repairs will solidify whether I really want to be a busnut or not. Though presently cut, bruised, and scraped... not to mention nearly crushed... I'm still anxious to get on out there and work some more. So I guess that answers that question!!
We're due to head out late tonight for a few hours to Wichita Falls for a roadside overnight. We'd like to camp the following night in Palo Duro Canyon SP, but I'll have to see how the brake holds up. That 10% grade down into the canyon could be too dicey to risk it. My Jake provides very litle help when idling down those hairpin turns, and getting first gear to lockup is hit or miss (the tranny supposed won't, but I've done it before and it's sooo nice).
Should be home late Friday sometime, if all goes well. Let's hope it does, and is altogether uneventful.
I'm sure missing my wife after two weeks... and the kids their Momma. "What a long strange trip it's been..."
bb
Brian Brown
4108-216 w/ V730
Longmont, CO
roadrunnertex
Brian,I am glad to hear that you came out from under your bus with out any major injuries.
This is a lesson for all of us don't get under a air suspension coach unless it blocked and chocked.
If it fall's on you it's to late and the old bus will not even say sorry.
Keep us posted on your trip back home.Above all be safe and be very careful.
If you need advise feel free to ask.
jlv
Hello Brian.
Thank you for being good enough to share.
Most of us clam up about our screw ups...
And then no one learns anything the easy way!
Keep this all in perspective: You have an old bus that has not been maintained.
You are well on your way to catching up on things.
Once you are home, you want to keep right on going, doing the appropriate preventive maintenance and worn parts replacement with every system and get ahead of the failure curve.
You have way more merit badges than many of the rest of us now!!!!
Oh, and best you don't tell your wife anything except how you were able to overcome the problems.
Unless you want to be an instant "used-to-be-a-busnut"
Buffalo SpaceShip
We made it home without incident, making the 900 miles in liesurely, short doses. We ended up going the northerly route, all Interstate through OK and KS. We revisited a great kids museum in Wichita that was even better this time around. Found a few parks, etc. New starter and batts spun her instantly to life, even after the two Walmart nightovers in the mid-30s.
I checked the ailing hub periodically, and felt no heat buildup. The last hour's drive through our environs north of Denver was the most stop and go, so when I pulled up in front of our house I felt all wheels and the oozing one was the only one not too-hot-to-touch... since its brake wasn't being used at all. I sure felt its absense a few times, and kept my distances waaayy long.
I haven't crawled back under there to see how much more gook grease came out (since I'm a little gun-shy lately  :D), but I'll get it blocked and look under there before I put her away for a few months. We usually get a warm spell in mid-January that I plan to dig into the bearings and axle. I also have a round of work to do on the front end (shocks, bearings, tires, etc.) before our travels start up again in earnest next Spring.
Thanks all,
bb
Brian Brown
4108-216 w/ V730
Longmont, CO
H3Jim
Congrats! I've been following your saga - you sure did have your share of troubles this trip.  Hope thats the last of them for a while.  I'm glad you made it back and all is well!
Jim Stewart
roadrunnertex
 ;D
Glad to hear that you got back home with out any more trouble.
Keep us informed on what ypu find with the greasy hub.
jlv
larryh
Now I feel vindicated on my assessment of your axle seal leak when You get ready tp pull wheels I can give you a big hint and description on how to remove as a unit so you don't have to pay for a tireman to remove for you. Happy holiday for you and your family.
LarryH
Savvy ponderable:
A cowboy's only afraid of two things:
havin' ta walk,
and the love of a good woman.
"This posting was generated using an environmentally friendly, self contained flatulence generator, therefore no fossils or neutrons were harmed in the creation of this posting.
Quartzsite,
Stan
It is almost impossible to remove everything assembled without a wheel dolly. You will need to remove the wheels first and then the brake drum. With the drum off, you will be able to see the source of the grease. If it is not coming from inside the hub, it is not necessary to pull the axle and hub, but is adviseable on a bus that is new to you and you don't know when the bearings were last done.
If possible, get somebody with a strong back to help. These pieces are heavy.
I have been following your posts...
Nice to hear you made it home safe and sound.  WHEW...
Good luck finding out what is going on, let us all know..
roadrunnertex
 ;D
Removing the tires & whell assembly.
I had made mention of this to Bryan when talking to him about the grease on the brake blocks and drum.
Some time back a fellow bus fan had made mention to use a pallet jack for a tire&wheel dolly.
I thought this is a good idea.
I located one on eBay for less than $50.00 and it will do the job just fine.
Also with 2 pallet jacks you can remove the engine and cradle out of a GMC Coach.
I saw a PD4106 owner do this a few years back.
One more item the size socket that you will need is a 3/4" or 1' drive 4" shell type socket used in removing the 2 axle nuts on the GMC Coaches.
I have seen them at NAPA stores and I think that OTC tool company makes them.
I use the name "Shell socket" because they are made with a very thin steel so the socket can get down inside the wheel hub.
Perhaps a bus fan that is a "tool" type person can add more to this type socket.
jlv
Paso One
Glad to hear you made it home safe and sound. I bet the kids loved the extended holiday :) Momma I bet was the least amused  but glad you were home. Cheers Paul
FloridaCliff
Brian,
Glad you and the Gang are home safe and sound.
Keep us posted on the fix.
Remember if the Wife says "is it all worth it", you can always say "At least I didn't catch it on Fire!"  ;D
Best Wishes from your friends is Sunny Florida. :P
Cliff
Mark Twain
