Neubie Various Thoughts
Started by TomC, November 06, 2006, 04:37:46 PM
DrivingMissLazy
One of the bigger problems with construction gensets is that they are air cooled and you must move large amounts of air to keep it cool. Not only does this create noise, it makes building a low noise enclosure difficult due to the air movement required.
Also, construction gensets are typically designed as throw away units to be thrown away after the construction project is finished.
Quote from: Chaz on November 07, 2006, 07:48:17 AM
I agree with you both! I think Generacs are junk!! (care to hear how I really feel?  ;D) I've owned some of their junk and regretted it. Never again.
Ok, so me trying to be the "creative one" (not always the best thing to do)  ;)  if I was to get this construction gen, bought a better muffler, sound proofed the bay -which I am doing anyway, what else would I have to do? Maybe have a small fan that comes on with the gen to keep air moving insde. Just curious. I'm always trying to be creative in some way and hopefully"occassionally" come up with a good idea that will help others.
Chaz
Buffalo SpaceShip
Good post, Tom!
Amen on drivetrain. It's about the only reason I bought my present bus... but it's the one thing that would be far too complicated and expen$ive to change. Just about anything else you do to a bus is cake compared to a repower or tranny swap.
I can't agree with everything you said, though. I've owned all three: gas genset, 3,600 and 1,800rpm diesels. The 1,800 rpm diesel is the only one I would buy again. Gas unit was a pain with multi-fuel and more maint. The 3,600's can be freakishly loud and vibrate a bunch unless one spends a lot of time soundproofing. Right, JR?  ;) I wouldn't like propane, myself, but that's just me. I like to fill the one big fuel tank and just keep motoring... but that's just me!
And unless one needs three rooftop A/Cs and "all-electric"v, a 6-8kW unit is plenty. Best not to buy a big unit and run it only partially loaded. More fuel and wet-stacking that way.
My $0.02, and great thread!
Brian B.
Brian Brown
4108-216 w/ V730
Longmont, CO
Kubota makes their own generators-both 18 and 3600.  One that comes to mind is the Panda line of Marine generators.  They are 3600 rpm and come in their own enclosure.  The 2 cylinder 8kw was the quietest gen I've ever heard.  My main point is that most of us don't need a generator that will last 20-30,000 hrs, like the 1,800 rpm's will.  If they last around 15,000 hours, like the 3,600rpm units do, that's enough.  I personally have a 10kw Powertech that is 1800rpm.  But next time will consider a 3,600 rpm, if it is also as quiet.  Good Luck, TomC
larryh
Buy a Generac if you need a anchor for your boat actually not good for that either, not really good for anything my 2 cents worth
LarryH
Savvy ponderable:
A cowboy's only afraid of two things:
havin' ta walk,
and the love of a good woman.
"This posting was generated using an environmentally friendly, self contained flatulence generator, therefore no fossils or neutrons were harmed in the creation of this posting.
Quartzsite,
I went through all these considerations and had decided on an 1800 RPM water cooled diesel. My only delay was in the outrageous cost. Then I discovered the Honda EV6010 water cooled RV generator which I am in the process for installing.
It is 6KW, 3600 RPM and is made to be enclosed for proper cooling. I'm making an insulated(fireproof) plywood box. This is less than half the cost of a diesel and probably quieter. It will last as long as I will at my low rate of usage.
The cooling system is totally selff-contained, no need for external hookups.
The only downside for gas gen seems to be the need for a gasoline tank, but my 4104 already has a 24gl tank used for the original AC engine.
Stale gas is not a problem if one uses Stabil. Generators should be run at least once a month under load anyway.
This thing is a HONDA, what more needs to be said!
kyle4501
Quote from: gusc on November 07, 2006, 07:12:31 PM
Stabil helps the gas last longer, but it will not allow it to last as long as diesel. I use stabil EVERY time I fill my gas can for the lawn mower & etc. Some times the gas will go bad after as little as 2 months. I buy gas from high volume stations to try to get the freshest to start with.
Keeping a gas genset exercised is mandatory if you want it to be usefull when you need it. ;D
NJT5047
Quote from: Buffalo SpaceShip on November 07, 2006, 11:20:19 AM
Good post, Tom!
My $0.02, and great thread! Brian B.
Right-O on the noise Brian.    However, as you state, with enough time and effort, even the higher RPM diesels can be quieted.  I've made great improvement with sound control.   The little Yamaha EDL 6.5 is quite tolerable now.  And it just sniffs fuel.  Been pretty good item so far.
High RPM Kubotas  are less expensive and much more compact that many low RPM units.  Jack Conrad squeezed a low RPM unit into the old condensor bay...which is where mine is located.  I didn't want to give up a bay for a genset.   If space isn't a consideration...or lack thereof, a low RPM diesel is preferable.
Regarding that engine thing...if you'll buy an MCI, the engine and trans swap is almost easy...installing sedan doors in bi-fold holes is still what I'd consider the most PIA operation...'course, I haven't raised any roofs either.   I speaks with some authority as one that has had to R&R a rear main seal.  Add to the list of PIA's....bleeding a DDEC once it's full of air.  Just had that thrill again last Monday.  Changed the oil and fuel filters.   The filters were in good condition...probably good for another couple years at least.  Somehow I have this mental image of trying to bleed the thing in 25* weather while stuck on the side of the road...so we changed the filters.  ;)
Note that it was cold last Monday and the newly installed block heater is a charm!  One hour plugged in and the old 2 stroke lites up and runs perfect...no cold smoke or anything.  Block heaters are highly recommended.  I'd install a simple electric block heater even with a Webasto or Proheat unit.  Sometimes the KISS method will get you going...and what if the Weeb don't lite?  Happens.
Cheers, JR
JR Lynch , Charlotte, NC
Ayn Rand
Kyle,
You're absolutely correct, Stabil is not magic. What it does do is keep the carb from gumming up. If anything I own sits all winter without running I always drain the old fuel out and add fresh even if Stabil was used.
Stabil will completely stop combustion if just a bit too much is used. I found this out years ago with my '53 JD Model 60 tractor. Took me three days of total frustration to finally realize the problem.
Fresh gas is a good idea anyway.
lostagain
The coach to me is a nostalgic thing: I used to drive it for a bus company in the 70s. When they got sold in '77, I thought those Courier 96s would make a nice motor home. Well 2 years ago when I saw one for sale I could not resist. We use it a lot in the summer. I spent all last winter renovating the inside into a 50s theme to match the exterior. It was tired 70s (lots of vinyl). I enjoy fixing and improving the mechanical side of things just as much in the winter. I am putting a turbo on the 4-71 Detroit now. The sense of satisfaction is priceless. All this is to say that it is not the money, but the enjoyment of it all that counts. That's the nature of the hobby. I'm having way more fun with it than I ever had with other RVs.
Lostagain
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Homegrowndiesel
Hey lostagain
YOU ARE a NEWBIE :)
#1 post Welcome to the "NUTHOUSE".
Courier 96? ???
4-71 Detroit, TURBO POWER cool. ;D
Glad to see your enjoying it.  ;)
How about a picture?
I love old busses. ;D
Bill
Aerodynamic Eagle & MCI 102a3, 102d3 and NABI series 50 transit. Busnut x4
lostagain
How do you post a picture? How about on my profile so it shows under my user name when I post? Thanks in advance.
JC
Blackie AB
