MCI-5B transmission options - Page 2
Started by Larry B, January 31, 2012, 06:23:29 PM
coachconverter
Dredging up a really old topic...
Has anyone put a more modern drivetrain in MC5A?  Like a Series engine and B transmission, or ISC, etc...
They have enough room for 50 series with a B400 with a Cummins it get a little tight because of the drop box
coachconverter
Thanks for the reply, that's what I was thinking too, Series50/B400.  Guess I'll just need to figure out the mounts and a few dozen other things...
Vertical clearance for a S50?
Neat job, take lots of pictures for us!
Happy coaching!
Buswarrior
I measured once, when I was at the non-rally in South Carolina and several guys had S50's in their MCI 8's and 9's.  There is about a half inch clearance vertically to the roof of the engine bay if the crankshaft is at the same height.  But - the S50 needs about half the radiator capacity, so a big opportunity to remove the roof, redo the whole fan situation, and reconfigure for a single radiator.  The guys with the S50's loved them, but they had sufficient room for transmissions that could live with the 3.73 drive ratio.
Lots and lots of transit buses ran their whole lives with the 6th gear locked out on the B400. 5th and 3.73 would be a charm.
If it will fit... that would be a fun ride!
Happy coaching!
Buswarrior
Quote from: buswarrior on July 03, 2019, 10:49:17 AM
Happy coaching!  Buswarrior
    BW, *is* there a 6th gear in a B400?  A B400 has gone into my bus and I've looked at specs.  All I've ever seen is a listing for ratios for 5 gears forward and reverse.  I hope I've missed something and I'll have more gears than I thought I did.
The Allison bus transmission brochure says it's a six speed - says ALL of the B series are six speeds.  The B400 has .75 and .65 overdrive ratios, fifth and sixth.  Says it's 28.3" long.  Doesn't say if that includes a yoke or drive plate. spec length on the MT 640 series is 30.4", or so says the interweb.
