10 spd or 13?
Started by Uglydog56, September 01, 2011, 02:55:40 PM
Oh, and out of the fog in my head...
To complete the whole story,
Shift pattern is like this:
      R        3/4         7/8
     1/2      5/6        9/10
To be proper and correct, there is a range shift in a Super 10, but it is automatic, triggered by the movement of the gear shift lever as it moves between the 5/6 and the 7/8 positions, pneumatically operated.
When shifting 6-7, it takes a little extra flourish with the shifter to get the splitter and the range shift to all happen, and get the gear in smooth as warm butter.
If you're going to try floating the gears, while in 6th, preselect the low range in preparation for 7, lift throttle, shift out of 6 and quick to the right wall in neutral, ever so slight a pause for the range shift to catch up, and then up into the gate for 7, and back on the throttle.
However, for the one I've got, my personal preference is to double clutch both up and down through the range shift in order to get a nice smooth shifting event.
And reverse can be run in high or low split, depending on the speed you'd like to go.
BW you again are technically correct.
But I an most other hands I knew/know that were/are truck drivers just get too used to the float to do it any other way! LOL
Don't mean we're right, just the way we has always done it!
