Driver's A/C questions - Page 2
Started by Skykingrob, August 02, 2011, 03:59:26 PM
Iceni John
Quote from: J_E on June 14, 2017, 06:23:15 PM
You will need a good path for condenser airflow, the compressor should be the low point in the refrigerant loop, and you should run the lines in a path that minimizes or prevents oil catches.
That's what I wanted to hear!   That makes sense to me, more so than folk just saying that condenser units always have to be vertical.   I'll have to investigate different brands of minisplits to see which ones can be best configured this way.   Ideally I want an inverter style with soft-start, and if it also has a heatpump that would be good.
My intention is to run it from my Magnum 2kW inverter that's powered by my solar panels.   I see no reason I can't have A/C powered by solar!   I know that a 12K A/C isn't enough to keep things comfortable when driving in hot weather, but I don't plan on often doing that  -  it's only for when parked.
Thanks, John
2kW of tiltable solar.
ccbmster
I mounted my mini-split on the back of my 102A3.  It is up above where the piano hinge is.  Working like a charm, and didn't take up any room that was being used for anything else. Love the way it turned out!!
86 MCI 102A3  Travel MI, IN, OH, VA, KY, GA, FL, and OK with most time spent in GA and FL 6V92 with Allison 740 Automatic
j.m.jackson
ccbmster, do you have any pictures of that install?
1969 GMC S8M-5303 #131
