air compressor cycling every 5 minutes, MC 5C - Page 3
Started by lostagain, July 25, 2011, 07:29:01 PM
lostagain
YEA, I FOUND IT :), Almost...
It is in the air door claw, somewhere between the red valve under the dash and the claw itself at the door.
I just come back from a drive, and the air pressure stays up forever with the red valve off. But leaks down in 3 minutes with it up. So after coffee, it's back to the bus with the soap bubbles. I hope the leak is somewhere accessible, because the PO had the stairs and the wall on both sides of it covered in ceramic tiles, blocking access to the claw, below the pass chair. So if I am lucky, it will be under the dash or in the spare tire comp. Will see.
Later,
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Good for you, the logical progression of alternatives.  I mentioned the air door possibility earlier, because I had the exact same issue though not as bad as yours.  I had to flip the red cut-off switch as soon as I parked too.
lostagain
So simple!! Once you find it, LOL.
As soon as I bent over to crawl into the spare tire compartment, I could hear it hissing. Off course I've been in there before, but the door claw was never pressurized. And you can't hear it from above while driving.
It is the line from the door air cylinder quick release valve to the air door cylinder itself. Big hissing hole in the middle of it. I didn't need soap bubbles to find it! So off to town after lunch to have a new one made up. It will be a challenge threading the new hose fitting onto the back of the cylinder, really tight access through the hole alongside the claw, but doable.
I feel great about my bus again.
A big thank you to all of you that contributed with tips and ideas and moral support.
This board is so great.
JC
JC
Blackie AB
