Budd style lug nuts
Started by gulfyankee, May 24, 2011, 04:48:04 PM
bigbrd
I just replaced a handfull of studs on my MC-7.  I have a printout of common studs for buses if that will help you.  On mine, you can remove the drum and leave the hub on the spindle.  Then you remove the nut on the backside of the wheel stud and pound it out through the hub.  I took the hub off anyway to clean the bearings and replace the wheel seal.  This made it a lot easier to work with with the hub on the ground rather than working with it on the bus.  Good Luck.  Studs usually come ten at a time when purchasing. $$
Rob H.
Loveland, CO.
1971 MC 7 8v71 with 4 speed
