Sticking Air Valve - Page 2
Sticking Air Valve
Started by kwood, January 22, 2011, 02:34:15 PM
Quote from: belfert on January 30, 2011, 04:33:30 PMIf you do find a sticking valve I would rebuild it or replace it with a rebuilt valve.  The air system is critically important to stopping your bus.  You don't want to end up stuck somewhere because of a bad valve.
True.  Protection valves (which don't open until they're fed a certain pressure) and regulator valves (which supply a fixed pressure lower than main pressure -- like one that doesn't allow more than 90 psi to the door system when the rest of the system is 120 psi) are more complicated but plain one-way valves are pretty much simple as rocks.  Open them up, clean 'em out and you should be ready to go; of course, if there's wear on the little ball or shuttle or wear on the seat, then it's probably a good idea to just replace the valve assembly.  Also, have a look at the ones that don't seem to be giving trouble.  I found a new one that I'd installed on my bus -- it came with the two body halves loose and it was leaking a bit of air; a simple tweak with a wrench tightened it up but there's always the possibility that they may leak.  As Brian says, all of those valves are fundamentally important and reasonably cheap.
kwood
Thanks, everyone, for the ideas.  Looks like we are going to be cold for the next few days.  I will try and take a look again this weekend.
