HEY GUYS GOOD 24V CHARGERS FOR CHEAP - Page 2
Started by boogiethecat, October 18, 2010, 09:28:19 AM
Fredward
i bought a 12volt Battery Minder at Northern for $49.00. Added two more alligator clamps in parrallel to the first two. I will connect them to the two 12 volt start batteries after I switch the main disconnect off. That should keep the 24volt part out of the equation. Obviously  I'll have to remove the charger and both sets of clamps before switching the disconnect back on.
Even the 12 volt model is designed to "maintain" multiple batteries wired in parrallel. I'll let you know if for some reason it doesnt' work.
Fred
Fred Thomson
chuckd
Just got mine from Bill via UPS, great looking device.  Will put some clips on it and give it a go.  I do not have a 24 volt battery charger on my bus, only a 12 volt charger.  So will use this when hooked up this winter to maintain charge.  Hopefully topped off batteries, and a block heater will mean I have a chance of getting it started after being outdoors for a month :'(
Chuck
