resistor to convert 12v led to 24v led clearance light
Started by bevans6, September 12, 2010, 02:35:23 PM
Quote from: cody on September 14, 2010, 06:42:58 PM
wow bk, I can't tell them apart lol
OK OK ol man I deserved that one for all the picking on you, I been doin'.
But hey do you remember right when you, Uncle Ned, Frank & I all went to Dixie Gun Works Museum and Uncle Ned got us all in on the family price?
We were looking at old civil war era guns and I asked if you remembered any guns like the one we were looking at. And proudly replied back with out missing a beat "No I was with the Union from the north!" Remember ? ? ?
Hi BK.  I appreciate the tip for the Setra lights.  If you can't get the pictures to work, what would be really helpful is knowing if the dimensions of the Setra lights are similar to the stock MCI lights.  They seem to be an odd-ball size and the stock fitting has a big hole in the bus that has to be sealed, so the trick would be to find lights that fit well into the stock locations and seal the holes!
Thanks very much
Brian if the ones on a MCI 5C are the same as MC8's, 9's, 96A & 102A's then they fit and cover and seal the hole!
The Setra 200 Series uses the exact same light as MCI. (even has MCI part # on it!)
We have replaced all of the old lights on all but our oldest Setra with them and love them.
I have had the LED's on my first 45'er for 3 years now and not replaced 1! Sure beats replacing 2-3 bulbs every other trip or two!
OK #1 & 2 are from the front the one on the right is old school incandescent lights and the one on the left are LED's
#3 & 4 are from the rear and the right is LED and the left is old school. (I know the pictures suck! I don't know if it was because the camera battery was dead and it kept shutting of on me, or if it was too dark to focus, or if it was just bad photography on my part.
The last one here is also of the back looking up under the LED's and over to the old school style.
cody
 ;D ;D  What bothered me the most is that some of the stuff thats in their museum, I still have and use.
JWallin
Just order yourself a 78L12 volrage regulator from DigiKey (digikey.com) and download a data sheet, which will show you how to connect it. It will be cheaper, and you can mount it with one screw to a metal surface for heat sinking.
Sean
Quote from: JWallin on September 15, 2010, 08:11:09 AM
Just order yourself a 78L12 volrage regulator ...
78L12 has a max input voltage of 27 volts.  I don't know about you, but my regulator is set north of 28 volts.  If your regulator is set as low as 27, you are probably not getting proper charge into your batteries.
FWIW.
JWallin
Oh, the 78L12's I've been using from National Semiconductor have a maximum input voltage rating of 35V (78LXX datasheet -http://www.national.com/ds/LM/LM78L05.pdf) Now this part may be a bit light on current depending on the load requirements, so the 78M12 in the same family may be an option. (datasheet - http://www.national.com/ds/LM/LM341.pdf)
If the load exceed 500mA, an LM317 (adjustable)  will provide upto 1.5 amps.
