truck washes
Started by ruthi, August 15, 2010, 08:21:13 PM
trucktramp
I've taken many trucks through the "streakin beacon" wash and have never had a problem.  You can ask those guys to not use any acid on your bus.  Acid will ruin your day if it gets on your aluminum.  I had a set of tanks done that were black to start and when finished, they were kind of white looking.  One other thing you will want to remember...have them use fresh water, not recycled water to rinse.  It will cost more but does not streak as bad.
Dennis Watson
KB8KNP
Scotts, Michigan
1966 MCI MC5A
8V71
Spicer 4 Speed Manual
rv_safetyman
Don't overlook the distilled water process that Ed mentioned.  Most water is reasonably "hard" and will leave surface streaking/spots if you just let it dry.
You can use regular water to rinse, but you will need to dry it what a good quality cloth.  Many top end coaches have a water treatment system on-board just for coach washing.
There is no need for a pressure washer.  A bucket, soap, hose and drying system is all you need.
Sometimes it is not all bad to have an "unfinished" paint finish ;D.  I don't worry about drying very much.  The Eagle siding does get spotty, but I use a quick wipe with some spray wax to get that off.
Jim Shepherd
Evergreen, CO
robertglines1
We have a friend that supplies wash to car dealers...says carpet shampoo on jug but we use on boat and bus cleans well and no streaks..far above stuff you buy at autoparts stores and cheaper....no water spots....ask your local car dealer what they use on lot.....The truck washes at piolt here won"t do a bus because of possible damage to finish. we use city water with that soap....will try to find brand name next time at boat...shinny is good keep grinnin ;D   Bob
ruthi
Thanks for all the advice. ;D
southeast most of the time.
