What size jack?
Started by it_mike, June 16, 2010, 05:22:21 PM
Jriddle
Here is some pictures of my manual.
John Riddle
Townsend MT
1984 MC9
Len Silva
You also want a pad to put under the jack.  I have a couple of one foot squares of 3/4" plywood.  You definitely need it on dirt or gravel, and even on blacktop on a hot Florida day.
Ed Hackenbruch
 I use a couple of 1'x2' x1/2" steel plates for under my jacks.
kyle4501
I've blown out the seals on a 10 ton jack while jacking up the rear axle of a school bus to swap tires with my dump truck.
That is why I like the 20 ton jack - less stress on the seals for the same weight.
The air over hydraulic is a very nice work saver - IF you have compressed air available.  8)
it_mike
Quote from: kyle4501 on June 17, 2010, 07:07:30 AM
That's what I was worried about.  I'll go with the 20T (on sale at Northern Tool...yeah!)
One of these days, someone will have to show me how to tie into the air system.
1980 TMC Crusader II
It's a bus - it always has or needs compressed air!   :D
I carry a generator and a compressor anyway, in  case I feel the need for a stealthy getaway I can air up the bus without running the engine.  I put quick connects and ball valves in two places - one on the ping tank where I put air into the system through the air dryer (always stop the bus on a compressor charge cycle so the purge valve is closed) and one on the accessory tank drain for taking air out of the bus system.
kyle4501
Quote from: bevans6 on June 17, 2010, 07:54:08 AM
I don't know so much about the always has part, but I can confirm the always needs . . .  ;D
When I have compressed air, I don't notice wether or not I need it - it is when I don't have it is when I seem to really need it the most . . .  ;D  ;D  ;D
One of my air over hyd jacks is either-or & can be used manually. The other one is air only - useless without air.  They use copious amounts of air too.
