Fire, Brakes and a hell of a scare
Started by FloridaCliff, July 06, 2006, 09:13:50 PM
roadrunnertex
Please post the information and required parts and photos on your new reworked exhaust system.
I am interested to see what is required for the change over.
jlv
Gary LaBombard
Where the heck is Fast Fred & how is he anyhow, I miss that dude!!
Gary
Gary
DrivingMissLazy
Based on his last post (as far as I know) he refuses to register on any board for some reason. Afraid that someone will spam him I think, but i do not recall for sure.
Although we had some disagreements several years ago regarding posting incorrect information, he did post some very good information and he did, in general, quit posting some of the data that was erroneous. He is missed by myself and maybe even Ace. LOL
Quote from: Gary LaBombard on September 28, 2006, 08:33:31 PM
Gary
DavidInWilmNC
Cliff,
My MC-8 has a shield over the muffler... I'm sure most MCI's do.  The muffler is way down close to the ground.  There's also no wood exposed anywhere in the engine compartment.  Perhaps you can also add some sort of shield to the muffler and cover that exposed wood with metal.  It's scary to think that all it would take to cause a bus fire would be a leaking muffler!  Have you started the bus up with no muffler?  I'm curious as to how loud it is!   ;)
David
FloridaCliff
David,
Good to hear from you.
On the GM's the muffler is in towards the front of the bus, one bulkhead forward of the engine.
It is mounted almost to the floor and sits vertical.
I built (rigged) a deflector/shield to get home with my muffler leaked.
It really is just in a bad location, of course with the V-drive there wasn't much choice.
And Yes, I will have to fire it up once with the straight pipes out the back ;D
Cliff
Mark Twain
DrivingMissLazy
It is my opinion that exhaust temperatures can reach 1000 degrees or more. More than enough heat to start combustion in most materials.
Quote from: FloridaCracker on September 29, 2006, 08:00:58 AM
David,
It really is just in a bad location, of course with the V- rive there wasn't much choice.
Cliff
JackConrad
We installed a pyrometer on our 8V71.  Running 65 on flat land, our exhaust temp runs about 650. We have not been on any significant hills yet to see how high the exhaust temp gets.  Jack
Quote from: DrivingMissLazy on September 29, 2006, 08:06:05 AM
David,
Cliff
Hello noise makers.
To get the real deal on the open exhaust, you have to get the motor to go to full fuel.
Motor has to be under load to get full fuel for any extended time.
Hard to do sitting still idling, it only gives the briefest small bark and that's it, as the governor backs it right off.
Take it for a drive around the block and really impress the neighbours!!
Dallas
Fast Fred has been a member of this board since 19-Feb-06 and was last active 18-May-06 and has made 8 posts. As a matter of fact, he was the fourth member of this board after Phil, Gumpy and Clarke.
Quote from: DrivingMissLazy on September 29, 2006, 06:45:53 AM
Gary
FF made a brief appearance over on BNO not so long ago, but that was it.
Others say he is active on some of his other hobby boards.
You gotta take a rest sometimes!
FloridaCliff
OK....The new exhaust pipes are in.... :D
Even though this wasn't a real difficult job, it was not without its challenges.
If you havn't worked with 4" exhaust pipe, lets say measure 5 times, cut once.
Don't overtighten or do the final snug until everthing is positioned and you are happy with it..
Best to get it looking good at the tailpipe and work backward as this stuff has very little room for play...enough said on that...
I had to weld up a bracket to hold and support the pipe about 16" before they exit the side(see picture)
I still do not have the internal mufflers....knock on wood.....they should be here next week....
I did run it without them......It sounded good(to a motorhead) but, it was too loud....On High idle it drowned out the engine running sound....
Anyway, hope that answered some the questions that may or may not come....
I will post some pictures below this with explanations.
Cliff
Mark Twain
FloridaCliff
Here is a picture of the original pipes that went into the muffler...
One new down pipe is installed.
Mark Twain
FloridaCliff
Another angle of the first downpipe
Mark Twain
FloridaCliff
Mark Twain
