Pocket door latch - help me find one for a thin door
Started by Brian Diehl, April 26, 2009, 06:56:09 PM
letz4wheel
Quote from: Brian Diehl on April 27, 2009, 06:16:03 AM
Well, you got 10 "atta boy's" for finding something.  Then you lost 20 "atta boy's" for sending my hopes up only to be dashed by the need to commit my first born in order to be able to buy it.  So, you are at a negative 10 "atta boy's" right now....
For a man in your position it is just chump change  ;D ;D With the hesitation I sense your firstborn must still be of the age they are likeable lol.
'78 MCI MC-8
4 speed
8v71
Nusa
Quote from: Brian Diehl on April 26, 2009, 07:44:59 PM
Steve, the first latch is interesting, but will not work for me.  My doors are surface mounted on the wall and exposed on the bathroom side.  The second latch is in line with what I need, but it needs to latch in the closed position.  Thanks for the ideas!
Actually, that first rocker latch would still work in the situation you describe. Mount it in the wall behind the door in the closed position instead of the door itself.
Brian,you might want to PM or E-mail BuscrazyinFL ,a member here on the board,he is a licensed locksmith down in FLa .Give him the thickness of your door,I'm sure he might be of help.Good luck.
Brian Diehl
Quote from: Nusa on April 27, 2009, 02:10:36 PM
yeah, I hadn't thought of that ...  Good point.
Brian Diehl
Quote from: letz4wheel on April 27, 2009, 02:04:01 PM
Likable, yes, but then my situation is a bit different then most others as I've adopted my children...  I've had less time to "mess" with their heads then most.  :-)  I'm trying to make up for it though!
Brian Diehl
Quote from: bobofthenorth on April 27, 2009, 01:10:47 PM
Without tearing my door latch apart and looking for a mfr. name I can't 100% guarantee that this is the same latch but I am sure enough that it is that I would wager a decent single malt.  I know the specs say 1-3/8 but my door it only a hair over 1" so either there are different versions of this hardware or you can get away with using it on thinner doors.
Thanks Bob.  I'll check my local hardware store out and see exactly how thin those latches can go.  Maybe 1 3/8" is just a standard width and therefore they just list that as the narrowest size by default.
