RV vs standard home toilet - Page 2
Started by ilyafish, November 24, 2008, 01:36:34 PM
JohnEd
I have had the "beige" plastic toilet in my old 74 Winnie.  It is the original, I think.  It holds a couple cups of water in the bottom for a seal condition alert.  Changed the sliding gate valve "once" since 90 and the water valve once at a different time.  I have full timed for maybe 4 years total and traveled 20K miles since I have owned it.  I couldn't ask for better service,  It is the cheap one with the two pedals in the front???  I would not go for the weight and mounting problems and operating limits of a household unit or an expensive Marine unit.  If it ain't broke!!!!
Just my 2 sense,
busshawg
Those of you that have a regular household toilet but are concerned about the amount of water that is used, try putting a gallon (or what ever size you wish) full of water in the tank. This will decrease the volume of water you use in each flush.
Have Fun
Have Fun!!
Grant
Sam 4106
Hi busshawg,
If you put a gallon jug of water in the tank of a 1.6 gallon per flush toilet, will it still flush and remove the waste?
On another note, I interpreted Jack,s post that you need to have both RV and house toilets directly over the holding tank, would that be necessary with a house toilet? I would think there would be water volume enough with a house toilet to carry the waste through a nearly horizontal pipe for whatever distance you wish. It works in our house. The only case where I would use a house toilet is if I couldn't mount the toilet directly over the holding tank. We boondock too much.
Thanks, Sam 4106
JackConrad
Quote from: Sam 4106 on November 26, 2008, 01:47:53 PM
On another note, I interpreted Jack,s post that you need to have both RV and house toilets directly over the holding tank, would that be necessary with a house toilet? I would think there would be water volume enough with a house toilet to carry the waste through a nearly horizontal pipe for whatever distance you wish. Thanks, Sam 4106
I think you are correct. A house type could probably get away with a sloped or flat run to the tank, But, it would use more water to complete the flush.  Jack
busshawg
I agree with you guys. I know of people who have put conatiners in their toilet tank to conserve water and it works. However I didn't believe in this method that strongly as we will be boon docking as well and I think if conserving is what is in mind the RV style would be best. I'm not sure what kind of climate you plan on using this bus but a toilet tank with water in would be a pain in the a** if it froze up. I just got back about five minutes ago of touring a MC* that is set up to live in ALL winter long, and we're in Canada. He is a full timer and is spending the winter in Winnipeg,MB. You don't really want anything going wrong with water works at -40.
Have fun
Have Fun!!
Grant
youknowwho
If I were you I'd put in a urinal plus the toilet.
JohnEd
What about a BooDay? :o ;D  Speaking of things you simply cannot leave home without. :P
John 8)
