Engine swap presentation questions
Started by mikelutestanski, November 10, 2008, 07:44:39 AM
lostagain
Jim, thank you for the offer. I will be pulling my engine out soon for a rebuild. I will probably find a bead roller while dealing whith various supplyers in that process. If not I'll let you know. I installed a turbo on my 4-71 a couple years ago. Great improvement! Now I'm going to rebuild it to turbo specs, for a fun project, and to see if I can squeeze a little more out of it. ;D
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
rv_safetyman
Dallas, I think that is the stuff we used to call monkey snot.
I try to keep the surfaces clean (no "glues").  But with silicone, I can see that your solution might work.
In other threads, I have talked about re-using silicone water hose and I have never gotten it to work.  Have you tired it on that type of application?
Jim Shepherd
Evergreen, CO
Dallas
Yes Jim I have tried it and it works when reusing silicone hose. This is what I do when I'm overhauling an engine or replacing a thermostat etc. It also peels off pretty easily if you have to remove the hose at some later date.
One caveat... make sure you get all the old coolant off the inside of the hose and the outside of the tube. The glue will stick to it, but seems to come loose later.
I also don't like using a lot of glue.. it's a real pain to clean up when you have to go back and do more work on an engine. I've probably spent as much time cleaning off "High-Tack" as doing an overhaul.
By the way... We always called it Gorilla Snot for obvious reasons, but I was trying to be nice for once.  ;)
Dallas
Quote from: rv_safetyman on November 11, 2008, 07:53:38 PM
