8v71 644 auto spacer??????????????????????????????????
Started by mccarlk, September 08, 2008, 05:00:23 PM
mccarlk
hi , i was wondering if any body knows were i can get either the spacer or dimensions of it, back a few posts ago i was told it was a 15/ 16 spacer, talked to a local detroit and allison shop and they had no clue, sam the mci guru  had the flywheel and the proper flywheelhousing but no spacers left, he said he had all the info on making one but he had a fire, can anybody help? this is all i need and im ready to install and get running, thanks , ken
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
 Ken, AZ Transmission will have it but you still will have to drill the mounting holes 1-888-395-1392 ask for Kim if you need the drive shaft he will have that also. (hang on Richard the guy is just looking for parts LOL)
DrivingMissLazy
Quote from: luvrbus on September 08, 2008, 05:14:42 PM
Yep. And that Kim was really a cute sweetie back then. LOL
mccarlk
DrivingMissLazy
Quote from: mccarlk on September 10, 2008, 11:36:09 AM
anybody else , talked to kim and he has none
Has she gone thru a sex change?  If so, it is a pity. LOL
Ken, if this fellow is still in business he may have 1  ( 928-680-4200) I believe he called it Coach Services  in Lake Havasu AZ  good luck
