Couple of questions
Started by fraser8, June 29, 2008, 10:13:17 PM
fraser8
First does anyone have a Prevost name plate from the front. The PO removed it and the bus is a no name brand and I would like to have one back on. I would prefer a reasonable price.
Second question, and yes I did a search. It was hotter than haidies here today and I have only one roof air, and is it noisy. I see information on heat pumps to create heat but in our stick house we have two remote air conditioners/heaters connected to a heat pump outside, it works good as we rarely get temperatures below 32F. The question is can I get a 110v heat pump that I can connect to the heating duct that runs along under the floor. It currently is used for engine hot water heat while driving and there is two separate propane heaters that have their own duct work for when we are parked. The hot water one goes from one end of the coach to the other and has vents that come out at floor level and as the coach is finished inside I can't run roof ducting. It would be nice to have it cooler and a lot less noisy. I appreciate your suggestions and ideas.
Fraser Field
Deroche, BC, Canada
Where the milk cows out number the people, but they can't vote
1972 Prevost, Detroit 8-71/740 Allison automatic, Jakes
Hobbies: restoring classic cars, www.oldambulance.com, arranging old car tours: www.coasters2010.com, www.canadiancoasters.ca
Retired Paramedic
