Mud Guard
Started by Lin, April 19, 2008, 09:11:37 PM
Lin
DML recently commented under another topic that rear mud guards could cause heat problems.  I tried checking it out in the archives but did not find anything.  Possibly my key words are wrong.  Anyway, I am talking about the type of flap that runs across the entire rear of the bus.  I have one and have not had any heat problems yet but have not driven the bus in hot whether yet either.  Direct info on this subject or help finding old stuff would be appreciated.
tekebird
Lin,
it is true, Engine Compartment air is evacuated from the bottom
ALL Gm's came from the factory with a splash Apron just aft of the rear wheels to induce more of a low pressure area to aid in moving this hot air.
Many people have the rear stone gaurds you have......and don;t have problems.......if you do have a problem, step one...remove it
Gary '79 5C
Lin,
You may wish to search "Mud Flap" for additional information and discussion.
Gary
Ocean City, NJ
Len Silva
A true busnut would have a thermostatically controlled retractable mud guard.
Hartley
Beware of going any place that actually causes MUD to end up on the mud flap.
You will have other problems before that should become a real issue.
They are also called debris shields, keeps the stuff thrown off the road from ending
up airborne and into stuff behind you. The Brush type work pretty good and allow fair air flow as long as they don't drag on the ground. They also collect plenty of the grit and grime that comes from oil leaks and soot so are not a fun thing to work with when dirty.
Just keep in mind whatever you install it must be very flexible to allow for uneven surfaces and to clear the ground when you bus settles down. I actually have considered using a chain type just to catch the big stuff....
Dave.....
FloridaCliff
Lin,
My 4905 didn't have any flaps when I bought it.
It had the remanants of one behind the rear wheels.
I replaced the entire thing with a piece of conveyor belt, that I fabricated to match the original.
I immediately noticed that it cooled better and lessoned the amount of DD mist on the rear of the bus.
This was after a year of diving without one.
I think if you replace the one behind the wheels you will have no use for the rear one.
Best of luck
Cliff
Mark Twain
DrivingMissLazy
Quote from: FloridaCliff on April 20, 2008, 03:09:56 PM
Lin,
It had the remanants of one in front of the rear wheels.
I think if you replace the one in front of the wheels you will have no use for the rear one.
Best of luck
Cliff
Well, I just learned something for today. I always thought the original flaps were to the rear of the wheels instead of in front of them.  Thanks Cliff.
tekebird
original Splash Gaurds:
GM
Rear of Steer ( approx 1/3 in from outboard on each side)
Rear of Drive ( full width)
FloridaCliff
Richard, Teke,
I just corrected my first post.
I was thinking front of engine, typing wheels.
The correct answer is BEHIND Wheels,
Whew!  :P
Cliff
Mark Twain
DrivingMissLazy
Quote from: FloridaCliff on April 20, 2008, 05:35:40 PM
Richard, Teke,
Whew!  :P
Cliff
Thanks. Now how in the H*ll am I going to unlearn that? LOL
