Oil Filter
Started by loadera10, March 01, 2008, 09:46:53 AM
pvcces
Jack, think of a plug with a standing tube welded on the top of it and a big hole in the bottom of the plug.
With that inserted in the bottom of the tank, liquids collect in the bottom of the tank, and vapors blow out through the hole in the plug.
At least, that's how DD made the one that we bought off of eBay. It works good.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
jackhartjr
Thanks Tom, that made sense.  I was picturing something that went in from the bottom.  So apparently the vent and drain simply screws in from the top as one piece?
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
pete81eaglefanasty
 Jack, Tom, Paul
As I stated before It has only one plug on the unit, on the bottom which is the drain and vent. Here is a couple of pictures of the plug and the bottom of the tank. My son took the plug out so I'll have these pictures to show you. As you can see it has the vent up the center of the plug.
          Pete & Jean
           FANTASY
WHAT EVER YOU DO, OR TO WHO YOU DO IT TOO, DO IT WITH A SMILE, IT MAKES IT LEGAL THAT WAY.
Stan
Obviously the design serves two purposes. It is also an overflow if you forget to drain the tank.
