Sitaflex
Sitaflex
Started by Danny, June 05, 2006, 10:17:19 PM
Danny
I completed covering two window openings today with .080 aluminum with Sitaflex - that is good stuff ;)  It was much easier than I thought.  I have been dreading this for weeks.  Just watch the preparation and it works great!
Danny
I have heard it said, "life comes at you fast".  I didn't know it would be in the shape of a bus  :-)
Hay Danny,
Now, it take's two weeks to remove the Sikaflex from your fingers! !  ;D
FloridaCliff
Nick,
Come on now.
You know as well as I that if you heat it up to 1200 deg it comes right off your fingers. ;D
Cliff
Mark Twain
Yes Cliff,
I have done that!..................Not!
LOL
phil4501
Put lotion on hands before you work with urethane, clean hands with scrubs and a bucket. Works good.
Rich (Prevost)
Id'nt that stuff cool. Back in 1994,  I was one of the worst "nay sayers" that could not believe that Sika would work. Now I do seminars on the stuff. It really works well on several levels. It stays flexible, like rubber, forever. It seperates the metals so there is no chance of electrolysis between dissimilar metals. It is strong.............It will hold large metal panels on the outside of the bus. Its a great sealant, no water will get past it. Etc.....................
Rich
800-468-5287
Danny
Oh, it wore off in about three days - as good as new   ;D   Ready for the other windows...
Danny
littlehouse
i know this might sound silly, but are you just glueing the pannels on or glueing  & then riveting  i just got to know,please
ray with the littlehouse on wheels
I want to live long enough to be a nuisance to my children
and i am!!
FloridaCliff
Ray,
I used both, but all you really need is the Sika.
I had a lot of rivet lines and wanted it to look right.
I only used the Sika to hold the panels 5' x 10' in place.
Cliff
Mark Twain
littlehouse
thanhs cliff, i'm going to remove all the old windows  & pannel over most of the sides, add alot of fraim, so that stuff sounds real
good to hold things together. really appreciate the info. but i think i'll wear gloves instead of using high heat to get the stuff off.
thanks again;  ray with the littlehouse
                   a '77 mc8
and i am!!
Danny
Littlehouse - I am just going with the sikaflex.  Nothing else is needed ... if the surfaces are prepared correctly.  This apparently is very important.  I followed the instructions to the letter and am very happy with the results so far.  Make sure you don't clamp so hard as to push out all the sitaflex.  The washers as spacers worked well.
Danny
Danny
One more point - I must say I was not looking forward to this step in the process.  However, it went very well.  Have everything laid out before you begin (clamps, material, etc.).
Danny
