mci interior phillips door screws
Started by christopher, January 19, 2008, 01:51:46 PM
christopher
i called mci for the 8 phillips interior screws. the upper hinge ones. i belive they are aluminum.
does anybody know the size of them and where a can buy some?
an alternative replacement would be good but these have an oversized head.
thanx
chris
mci5c 78
JackConrad
Guessing I would say 5/16 or 3/8, not sure if they are coarse or fine thread.  Best bet is to take one out and look at it. For replacement bolts, check out www.boltdepot.com  They just about every style of bolt ever made and in several grades and metals.  Jack
Tom Y
Chris, You have a sedan door? If so they are not alumium. 3/8 fine thread steel bolts. I plan to use hex bolts and cover over the whole hinge.  Tom Y
Tom Yaegle
Hi Chris,
There are lots of online hardware suppliers that may have what you need.
Here is one I used in the past.
http://www.fastener-warehouse.com
Good Luck
