Ready for flooring! Subfloor or not?
Started by grantgoold, November 29, 2007, 09:49:09 PM
grantgoold
I am ready to lay the laminate flooring. I would like opinions on rather to lay a 1/2 plywood floor down on top of the original flooring as extra strength, seal and sound barrier?
If I go with the plywood, I would lay a moister barrier between the original floor and the plywood and then the suggested barrier on top of the plywood prior to laminate. I am going with a 8mm with padded backing that I picked up from Lumber Liquidators. Beautiful stuff, easy to install and very cost effective.
Thanks for the input!!! :)
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
Tenor
In my case, I had a good original floor that had the tunnel covered by the PO so I decided just to put the laminate flooring on top.  Since I wasn't doing a roof raise, and I have tall friends, I wanted to keep the head room.  As for a vapor barrier, I don't know why it would hurt if you decide to add a sub floor - just be sure to use tongue and groove plywood to keep it from sagging at the joint.  I also read in this web (it is from Gypsy Journal, but I renamed it in my Favorites) http://www.gypsyjournal.net/bus_project.htm an interesting alternative to plywood for the floor.  Hope this helps!
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
