road heat - Page 2
road heat
Started by jlaney, September 25, 2007, 06:24:31 PM
Iver
I have a MC-9 and have also removed the fans and ducting for the road heat.
I would like to run a loop from the main lines where the main heater core now sits to a small heater by the passenger seat.  How should I set up the plumbing? Do I need a circulation pump?
           Thanks,  Iver.
Abbotsford, British Columbia, Canada
"Life may not be the party we hoped for,
But while we are here we might as well dance".
jlaney
iver
my prevost has a 871 engine and the hot water from the engine run up into the bus above the floor , down the left hand side which is the drivers side. and go's down into the a/c bay and hooks up with the circulation pump. i am not using any pump except the engine water pump to circulate the hot water up to the front defrost unit. the line start out as 1 3/8 copper. j.t.
j.t. laney  tyler texas 1980 prevost lemirage
