Is it just me?
Started by captain ron, May 10, 2007, 07:18:44 PM
HighTechRedneck
I haven't had any trouble with the forum being slow on any day lately.  There were the problems with notification emails right after the change over, but even those seem to be working well now.  I've been pretty satisfied with the performance since the change.
Thanks for the input guy's..
The system seems to be fine and running normal.
Ron, let me know if this continues for you and we will all pitch in a buy you ad ware remover.....Lol
HighTechRedneck
If just a few people are experiencing lag, it could be a bad route somewhere along the way.
If you are still having the issue, maybe you could post a traceroute.
If you are computer savvy and familiar with the command window, open the command window, do a tracert to www.busconversions.com and copy/paste the results into a reply to this thread.
For those not familiar with how to do that:
  • Click Start Button>Run> then type in cmd and press enter
  • Type tracert www.busconversions.com and press enter
  • Right click inside the command window and choose "mark", then use your mouse to select all of the text following the "tracert" command.
  • Press the enter key.
  • Switch to the window for replying to this message, click in the text box where you want to put it and press the "Ctrl" and "V" keys simulataneously.
If a bad routing point appears, Phil can report that to the server hosting support and they should be able to help.
