steeringwheel shaft for gm4106
Started by dutch, April 11, 2007, 03:36:15 PM
dutch
hello folks
where o where can i get one???
i need the whole shaft from steeringbox to steeringwheel(the shaft that has the ujoint on it)
i'm going on a trip soon si i need one yesterday!!!!
thanks dutch
tekebird
I think I gave one to Luke last time I took parts down there.
WVObus
Contact Dick Wolfert @ 727-856-6862
Aren't there two drive shafts for the steering?  One going from the steering column to the miter box (90 degree gear box) and then another going from the miter box to the steering box?  Did you loose the shaft?  If the U joints are loose, have new U joints installed.  Good Luck, TomC
tekebird
Luke also has the other shafts as well
dutch
he tom
well the ujoint are bend and have worn out the holes were they are supposed to be attached to the shaft.
maybe i can weld them smaller so that the ujoint doesn't move.
dutch
LUKE at US COACH
Hi Dutch & Folks:
Dutch, you are talking about the safety of yourself and the passengers on your coach.  In my mind there is only way to go and that is to replace steering parts with original, if available!!!
You can call me toll free tomorow at: 1-888-262-2434, and I will try to help you.
I Hope this HELPS!!!
Happy & SAFE!! Busin' to ALL.
LUKE at US COACH
dutch
hello luke
yeah i've been thinking about it and i think i should not mess with the broken one and replace it with a brandspanking new one.
i can go the welding way and spend hardly any money(but jeopardise my life) or spend some money and live.
mmm easy choice.
thanks
dutch
Barn Owl
Dutch,
I think this man is parting out a 4106.
http://myworld.ebay.com/ebaymotors/gmbus5246/
Keep us updated on your progress.
