8V92TA Thermostat Question For Clifford
Started by RJ, April 12, 2023, 03:53:57 PM
Cliff -
Do the thermostat housings on the 8V92 engines use gaskets, or instead something like Permatex's "Form A Gasket?"
TIA,
Quote from: RJ on April 12, 2023, 03:53:57 PM
Cliff -
TIA,
Gaskets shoot me a PM with a address if you need 2 I have a wall full ,the T stat sits in a grove in the housing with a rubber seal and gaskets are the same thickness as the T-stat flange to keep  from screwing one up
