Detroit 8v92 bud heater install
Started by hitch2626, March 21, 2023, 04:16:44 PM
hitch2626
I have a Detroit 8v92. I am looking to install a bus heater.  I am not sure where to tap into the coolant system. Has anyone done this before or maybe have some pictures.
Utahclaimjumper
 A BUS heater  or a BLOCK heater for the engine??>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Quote from: hitch2626 on March 21, 2023, 04:16:44 PM
There is a plug on top of the water pump at the top hose connection,then a return plug on the other side at the front of the block to make a loop both are 3/4 inch plugs , or you have plugs in the heads, with plugs stay above the freeze plugs if you tie into a plug below the freeze plugs the water goes in the oil pan,for a block heater there is plate with 4 bolts on the right side for a block heater
