1999 MC-12 C10 Aux Pump / overheating
Started by ustenor, June 23, 2023, 03:50:48 PM
ustenor
During the night, all is off and a noise comes from the engine bay. Checking in the morning finds the aux heat coolant pump making a racket. I disconnected it. Now leaking coolant and Now bus is overheating. Can't I run without the heater pump connected? Can I bypass it?
Dan Keeton
Destin, FL
1999 MCI MC-12 / Cat C10 Engine / Old Prison Bus
freds
Generally yes, normally there is a valve to turn off the heater circuit.
The booster pump or the circulation pump should not be running unless the system is asking for heat,I don't know how one or the other is causing the engine to overheat unless the coolant is very low from leaking look for valves ( ball or gate) on the engine and shut those and it should stop leaking
Quote from: freds on June 24, 2023, 01:53:58 PM
