One side settles faster than the other.
Started by Sebulba, December 11, 2021, 02:06:39 PM
Sebulba
Hello all,
Just something I have noticed.  The drivers side of the bus settles down to the bumpers after several hours and the right side still isn't touching the bumpers after sitting over night.
I wonder if I can correct this or even if I should care.
Ideas?
Seb
Bought a 1997 MCI 102D3 with Allison B500 on November 17, 2021 in Syracuse, NY.  Commenced living it that day and  drove it to Florida and New Mexico.  Converting as we go.  https://basicsuds.com
richard5933
Obviously you have a leak on the low side.
Likely in the rear of the side which has dropped.
Could be the air bags, could be the ride height valve. Could be just a loose fitting, or could be a failing air line.
Leaks don't get better on their own. They do get worse, usually at the most inopportune moment.
I'd suggest getting it fixed.
You've got an air leak in the driver's side rear suspension.
As Richard said, it could be the air bellows, or the leveling valve.
Fix yourself a spray bottle of soapy water and start squirting everything back there down.
My first guess would be the leveling valve is the culprit, but you won't know until you do the squirt bottle test.
Just don't crawl under there w/o blocking the body up solidly, first.
FWIW & HTH. . .  ;)
Tedsoldbus
We know this is your shake out cruise Seb and you have had issues. It happens. First trip in my bus the engine shut off at 65 MPH with my little buttercup at the wheel for the first time. It was just a bad relay. The engine was fine, but it was memorable. Don't get discouraged. But READ CAREFULLY what these two guys just told you. If you fire up the bus and let it run for 10 minutes or until it is level, then shut it off, run to the back left side, and listen. You should hear it leaking air. As said above, do NOT get under it. Air going out means bus coming down. If it is a slow leak you won't hear it. Soapy water in a spray bottle is great advice, but squirt without getting under the bus. Squirt soap on anything you can see that does not look like wires. If you see bubbles take a picture and post it.
Hang in there Sebula.
1980 shorty (35') Prevost
6V92  HT 740
Lake Nottely Ga
Bus name "debt"
Sebulba
Kinda what I was thinking.  Now that you have confirmed, I will start serious inspection.  Unfortunately where we are in TX right now the wind is furious.  Not the ideal situation for listening for a leak.  :o
By the way, the air leveling valve, generally speaking, where would I find that and what is its general appearance?
Thanks :^
Seb
Bill Gerrie
This is what to look for. One in the front and two in the rear. They have a small arm to the body from the arm on the valve.
Sebulba
Quote from: Bill Gerrie on December 15, 2021, 06:15:43 AM
Great, thanks
Seb
Seb. go to a Dollar store and grab u a few bottles of the kids bubble liquid, any leaks will be easier to find and the bubbles will be big enough to see. shop air or a portable air compressor will help keep things aired up with out the engine running.
Sebulba
Quote from: Van on December 15, 2021, 06:35:23 AM
Nice suggestion, and definitely more fun.  ;D
Seb
Tedsoldbus
Hey Seb,
Was looking at your recent question about heating fuel. I have a 35 gallon propane tank for my furnace and it lasts a year so have no advice for you on that. Sounds like there are guys with diesel heaters that love them and will help you with that. Sounds a little spooky running fuel lines around the bus, but propane leaks can make a really loud boom, so I can't fault your logic.
But I was waiting to hear if you found your air leak!!!! So I will ask you that on this thread.
6V92  HT 740
Lake Nottely Ga
Bus name "debt"
Sebulba
Quote from: Tedsoldbus on December 16, 2021, 06:33:34 PM
Hey Seb,
Thanks for your input.  Haven't had a chance to look for the air leak yet.  Just arrived in Albuquerque yesterday.  I have located the valve though, just by peaking around.
Seb
Tedsoldbus
These guys will help you learn it. We always had newer RVs over the years. I'd just check the oil and off we would go. I found out early on that it is not a good idea with a 40 year old bus! These gents have taught me so much. Travel safe.
Ted
6V92  HT 740
Lake Nottely Ga
Bus name "debt"
