How do I remove this side glass?
Started by Jinxie, June 06, 2021, 06:43:42 PM
Jinxie
1977 MC8
The glass on the driver side is full of moisture and needs to be changed out. How do I remove it? I know it has a locking seal that needs to be removed from the outside, but what are the next steps? What tools do I need? I am going to a bus wrecking yard this week and I have to remove myself....without breaking! I will likely get a glass company to come install in my bus. Does it remove from the inside or outside of the bus? Also, are they interchangeable from right to left? Thank you
On the inside, pull back the rubber edge, the one away from the glass, and find the fasteners.
Happy coaching!
Buswarrior
ol713
   HI;
       Can you tell us where this "bus wrecking yard" is?
Jinxie
Ha....something so simple....thanks! I never knew.
I am located in Manitoba, Canada.....if there is something your looking for I can check it out for you....??
Raymond smith
I'm looking for a good used 15.5" pull type double disc clutch or just the pressure plate. I'm in Thunder Bay Ontario. Hi neighbour. Provide us with a phone number for this wrecking yard if you don't mind. Thanks. Raymond
1957 4104-3632 & 1989 mci 102c3
If it doesn`t fit properly the first time, Get a bigger hammer
To remove one in a wrecking yard, pull out the locking strip and use a utility knife to cut away the seal. Those seals harden with age and good chance of cracking window trying to push it out of seal. Unless you want the seal too.
