I thought I should say hello
Started by Bearmtnmartin, February 07, 2021, 07:43:51 PM
Bearmtnmartin
I have been lurking for quite a while. I have a 1981 Wanderlodge FC35, but it is less and less Wanderlodge all the time. I am in the middle of swapping in a Cummins ISM and a 13 speed roadranger, and I find this forum has a lot more applicable information than the WOG group for that kind of thing. I have picked Brian Deihl's brain a couple times along the way.
richard5933
Welcome!
Good looking bus. Front engine?
dtcerrato
@Bearmtnmartin
Brian has done some awesome work on his bus. We met up with him & family during our Alaska journey & was very impressed!
Welcome! A wealth of knowledge here...
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Bearmtnmartin
Thank you, and yes it is a front engine. You would think that would make the conversion easier but I have about 200 hours into it now and I figure at least 100 to 150 left. But I did it because I could, rather than because I needed to so whatever.
Brian Diehl
Doing it because you can is WAAAAY better than doing it because you need to.  The "do it because I want to" projects are way more fun than the "do it because I have to" projects.  Keep on keepin on!  Looking forward to reviews and pictures on the final product.
robertglines1
outside the box is more fun than inside.. I just never fit inside.  Bob
Are you going to turn around the main box to make it a triple overdrive 13spd?
Bearmtnmartin
Well Tom, I thought 90 at 1950 for those late to work mornings would be plenty with the usual layout. I did consider a 3.55 rear gear so I could run in direct for better mpg but I could not find one for the old axle. But that would have got me 119 at 1950 in second over. As it is I will be happy with 70 at 1524.
6805eagleguy
Right now I run 74 mph at 1400 rpm in 6th
Drop to 5th for 68 mph at 1500 rpm
So glad I don't have a ht740 :)
1968 Eagle model 05
