Cat 3176 engine codes 72,73,74 wont start ecm? speed sensor?
Started by rgrimard, April 17, 2020, 12:37:37 PM
rgrimard
Hello,
I have a MCI 102c3 with a Cat 3176 that all of a sudden won't start (only for a second with either) and flashes 72,73,74. All the injectors are faulty... so it is probably an ECM issue. However, has anyone seen a faulty speed sensor cause this? Just trying to avoid yanking the ECM (not the easiest unit to get to in a bus) if at all possible.
Thank you,
Ray
I would inspect all the wiring grounds and connectors for the injectors first.
