Basement Paint
Started by 64MCI, April 06, 2020, 11:25:27 AM
Keep in mind of condensation between rubber mat and aluminum floor
Dave5Cs
With the rubber Mats you will attract little horses also and then have to muck out the bays and buy hay, I don't know??? :o
freds
I would like to replace my plywood, but it has about two inches of sprayed foam on the underside, so a much bigger project than just replacing the plywood.
Jim Blackwood
I'd like to try those horse stall mats, but I sure don't want to be attracting more pets, and horse piss is going to wreak havoc on the aluminum. Do those little horses like to kick things? Last thing I want is dents in the bay doors.
The porosity might be a good thing if it would let water dry out from under the mat.
richard5933
There are products similar to the horse mat material available as sheet flooring. It's used in some gyms and workshops where a durable but softer flooring is required.
I've used a 1/4" thick roll of this to cover the exposed painted plywood in a couple of my bays. It really holds up well and keeps the paint underneath from wearing away as things slide in and out. I used a pneumatic staple gun to tack it down so it would be easy to pull back up when necessary.
This isn't where I got it, but it shows what's available: https://www.greatmats.com/rubber-flooring-rolls.php?gclid=CjwKCAjw7LX0BRBiEiwA__gNw9BabC0-B5hoMUdNpF8ON6rMVWZHLUq88GDyE6gI9O6Bj4Tj_tG22RoCOFYQAvD_BwE
Won't do everything for everyone, but it's an option.
Well, you could coat the floor and couple inches up the side with Rhino lining or similar.
