Power Steering Pump Pressure - Page 2
Started by luvrbus, February 19, 2020, 06:17:29 AM
6805eagleguy
Quote from: luvrbus on February 22, 2020, 03:46:24 PM
I do but if you do F/B they have a lot of schematics for Eagles check out Vintage Bus Mechanics ( not the same as Grease Monkey) and Eagle Owners if they are not posted they will send you one Steve is good about that
Thanks Clifford
1968 Eagle model 05
DoubleEagle
Quote from: luvrbus on February 28, 2020, 07:29:10 PM
I checked only one I have left is for the model 15
If you want to part with your air line schematic for the 15, I would appreciate it. I just got all of Boomer's Model 15 manuals, but it did not include that. I have a schematic mounted on the electrical panel door, but it's hard to stoop down that far. You could include it with the LED lights when they happen.
Walter
Dayton, Ohio
If that doesn't work out, remove the door and take it to a copying outfit and have copies made, maybe enlarged 50 to 100 percent. I had that done with my wiring diagrams and brake line diagrams. Much easier to follow.
DoubleEagle
That is an idea, but the door on the Model 15 is fairly big. I can picture being thrown out of Staples, Kinko's, etc. Which outfit did you use?
Walter
Dayton, Ohio
freds
Quote from: DoubleEagle on March 01, 2020, 09:52:47 AM
I have photo stitching software if you would to take multiple pictures moving about 20 percent a time with 40 percent in view.
That's how I ended up scanning all the circuit diagrams for my bus.
