DIY Hydronic plumbing and heat distribution
Started by freds, December 30, 2019, 03:13:17 PM
freds
I remember seeing another busnut's design where he routed channels for PEX tubing into plywood for radiant heating.
While I won't be using it, I came across a product that has channels with a preformed aluminum skin for better heat distribution.
You have to custom order from the manufacture and it normally comes in 4 X 8 foot sheets.
However for remodels they have 2 X 4 foot sheets, that you could also install on the walls.
Seems like it might be a nice system if you are converting a bus from scratch and you need to replace the plywood floor anyway.
More info:
https://www.warmboard.com/warmboard-s
