slobber tubes slobbering slobber
Started by coolbus, June 18, 2007, 10:54:22 AM
Utahclaimjumper
Aren't the crankcase vents using the crankcase pressure to vent.?? >>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
DoubleEagle
Quote from: luvrbus on December 14, 2019, 07:52:21 PM
Houston Metro buses had the air box drains tied into the muffler I thought that was unique but wondered what happen when the engine got tired  ,you shouldn't have but a few drop if the engine is healthy
If the Metro buses had rest rooms, they could have added that liquid to the exhaust as well, GM style.  :o
Walter
Dayton, Ohio
robertglines1
air box and crankcase are two  different areas completely separate from each other on 2 stroke. The air box is your pressure area before entering cylinder. Crankcase operates at neutral pressure. Air box over 6-900 rpm is you intake to cylinder should be boosted by blower at that point.
Utahclaimjumper
After dealing with two stroke Detroit's for 30 years ,,I understand the princibles of operation..My point being that both systems do basicly the same job even tho not connected other than sharing the same block..>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
72 VW Baja towed
