Uh Oh! I think i made a big boo boo - Page 2
Started by WoodenBoat, September 15, 2019, 01:16:19 PM
Geoff
All this talk about wiring and such.  I have some mice and pack rats that can find the hardest wires to get to and chew them up.
Now the little bastards chewed through the steering column rubber boots to get in and chewed on some dash wiring.
Geoff
'82 RTS AZ
MagnoliaBus
If you look at the batt cables, you should see red tape on the cable at the end of the pack (24V) and yellow tape for the center tap cable.
On newer coach the cables are color coded.
You would also see red and yellow tape on the cables bolted to the Vanner equalizer.
Denis, North of Montreal, 1989 Prevost XL40, 8V92TA HT740
MagnoliaBus
Quote from: Geoff on September 28, 2019, 10:50:25 AM
You need a cat !
robertglines1
or snake---By the way they do air lines also--Made so good with the addition of soybean oil in 90's to date--a( Unnamed Country) better Idea. The PVC (made with cynaide ) was causing cancer in little fellows.  Only thing you can do is seal her up best you can and use all the tools to stop you can.  Add to Prevost color blue is 110 V White is 110/120 ground. Add black with white stripe as chassis ground source-= Sorry about rattling today-Electric is one of the most time  consume things. 2nd by air lines (don't like push fittings at all)      My bad attitude for awhile --- probably.
Dave5Cs
We use dry sheets and it keeps them away. I just throw a few around and down in the bays too. All dry foods are in sealed glass jars that can be or it comes off the bus.
