Tach sending unit for 6V92
Started by chuckdrum, July 29, 2019, 03:04:24 PM
Looks like the weight or magnet came off, from the clean square where it was attached. Go get a dime sized disc magnet and glue it on where the square is. Make sure it clears the pickup by 30 thousandths or so and give it a try. Youll only be out 30 cents or so. Cheap fix possible.
chuckdrum
Richard 5933-
Awesome!  Thanks so much for the link!  (already sent in the order)
Chuck
Chuck
1979 MCI 5C
Seattle, WA
chuckdrum
Today I finally got around to replacing the sender with the part that Richard5933 recommended.  It's a universal part so I had to bend the bracket 90 degrees and drill a 1/4" hole for the mounting bolt; I wired it up and decided to try that first step before going thru the task of removing/replacing the old magnets on the pulley.  IT WORKED!  Didn't have to replace the magnets and the whole procedure start to cleanup was about 35 minutes!
I'm a bit baffled why the shop couldn't figure that out when you guys did with just a photo and a description but, whatever...
Richard5933 gets the prize!!!  I'm very happy to have a functioning tach for my upcoming 6K mile trek through the Heartland of America.
Chuck
Chuck
1979 MCI 5C
Seattle, WA
richard5933
Quote from: chuckdrum on September 13, 2019, 08:30:36 PM
... I'm a bit baffled why the shop couldn't figure that out when you guys did with just a photo and a description but, whatever...
Chuck
Glad to hear it worked out and was so easy.
Why couldn't the shop? Simple. They didn't want to.
