60 series EGR motor
Started by randsgmc5302, August 07, 2019, 12:07:16 PM
randsgmc5302
 Hi I have a 97 DL  with a Ddec IV  series 60  have a 2003 series 60 EGR motor  with 150,000 miles should I leave it a EGR motor or converted back to a non-EGR motor  both are ddec IV  thanks Randy
Are you sure about the 97 being DDEC IV?
I always remembered it as still DDEC III?
If the chassis is EGR exempt, that's what i'd do.
Straying from the rules is going to hurt, when they regulate....
Happy coaching!
Buswarrior
randsgmc5302
 Was a reliable built in 06 and updated to with a ddec IV ecm
robertglines1
I have a 2000 60 series with ddec IV. pre egr.   should tell you on valve cover. All I know any thing after that is prob a egr engine (known to burn more fuel ) and alot more complicated.  I know there is a differance in turbo and sensors. Will look for a more definite answer for you.. there is a differance in ar ratio in egr engines. Bob
Boomer
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Don't worry about the EGR have somebody set the regeneration at 3000 rpm it will never see 3000 rpm and Boomer is correct the 2003 should be a DDEC V some early ones were IV on 12.7
randsgmc5302
 Just checked this morning both motors are definitely D decIV
Bill Gerrie
Are you Randy from Wisconsin with the series 60 in an MCI? Coming to Clio on August 14 if you are?
randsgmc5302
 Yes that's me Bill that's my kids DL I'm working on right now
Bill Gerrie
Randy
With a handle like that and 5302 I figured it had to be you. I know it is a long way for you but hope to see you in Clio. May be the last one according to Marty.
