Rear end gear lube
Started by Flight102C3, May 25, 2019, 05:41:06 AM
Flight102C3
Good morning!  What are we using for gear oil in rear end? 80w 90. I have a 102C3
Utahclaimjumper
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Jim Eh.
Are you topping up or replacing?
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
sledhead
so how many gallons are in there if I want to drain and change it ?
thanks   dave
dave , karen
GnarlyBus
My MC9 has takes 4.5 gallons. The manual lists it right at then end of the rear axle chapter on the specs page. I'm getting a 5 gallon bucket when I do mine.
Full-Time since 2015
Use the GL-5 rated 75/80 the GL-1 through GL-4 is old  school
Iceni John
Quote from: luvrbus on May 26, 2019, 09:58:36 AM
I've been using GL-5 85W/140, which is what my Rockwell manual recommends for the temperatures here in SoCal.   I also use it for the front and rear hubs.   Is that OK?
2kW of tiltable solar.
We used 90/140  Lubrication Engineers synthetic in our 4104. It flows like molasses at room temperature.
Flight102C3
Sorry ended up out of town working! Did wheel end work. Drained all. Thinking 80w90 old school. Thanks
I like Lucas Hub Oil for oiled hubs, it is very persistent, sticks to the bearings, and resists leaking.  Gear oil has extreme pressure additives that aren't needed for roller bearings.  MCI recommends SAE 30 Engine Oil in the front hubs.
