MCI Removing the Lav
Started by Aviator, February 19, 2007, 07:33:58 PM
Aviator
Hi All
We are currently looking for an MCI ( -9 -12 or A3) to convert and we are planning our work flow.  How hard is it to strip out the Lav and more importantly, the lav holding tan?  Does the tank have to come out through the bottom via the engine bay, or can you remove some floor and pull it up through the top??  My dad is a retired -Hound supervisor and they never had to get them out so he's not much help in the matter.   ::) (they just fixed leaks while they were in the bus)
Larry
Larry
1992 MCI 102C3
Northwest Indiana
Hi Larry,
Welcome!
The MCI lav's are a difficult task for sure... The Lav itself is not so bad to remove. Just alot of screws and the flooring
may be a challange. The truely hard part is to remove the tank. The tank is supended from underneath the lav
in the engine bay. You will need alot of sawzall blades to cut the stainless steel straps and they are hard to get to.
It took 2 of us almost one full day to remove the tank......Yea, Lots of cursing that day. "It's a Shi**y Job"
Let us know when you are ready and we can coach you through it.
Good luck with your purchace!
Nick Badame-
Tin Lizzy
Took me about 4 days of part time hard work by myself to get that sucker out!!!!
They built those bathrooms bomb proof for sure. The tank was indeed the hardest part. There is a few layers covering the tank and the straps were hard to find. tight space to work in didn't help either.
I was sooooo happy that the bathroom had not been used for a long time and the tank etc was bone dry. The base for the walls etc were tough too.
I think I took a skill saw to the floor to get it out finally.
Harry
Tin Lizzy
1972 MC 7
Calgary, Alberta
ChuckMC9
OK, it ain't that hard. I was scratching my head and cussin until I posted asking for some help over on BNO. The gentlemen talked me through it - once I had the experts' help it came out in a jiffy. The secret is the two mystery bolts that aren't at all immediately obvious. It does come out through the streetside ER panel. It is a dirty job, but really, in the overall scheme of building a conversion it really plays a small role.
If/when you get ready, just repost and we'll guide you through it.
We can also share a tip on the floorpan removal inside the RR.
Good luck with your search!
Jerry32
ChuckMC9   I'll Remember  you when I get mine home and need to pull the lav.   Jerry
1988 MCI 102A3 8V92TA 740
JerryH
The lav interior wasn't that tough to remove.
The tank below was more difficult, but once I figured it out ... it went (somewhat) quickly -- all things being equal.
But nonetheless, it was the nastiest process of the demo of the interior.  Have your latex gloves and dust mask handy (in general) ... but especially for the restroom removal.
Good luck.
Jerry H.
NJT5047
Hi Larry, Welcome to the 'bussin world!
FWIW, get one of the ex-NJTs and you don't have to dink with restroom removal.
There are a good many coaches used for shuttle and commuter routes that didn't have restrooms.
Finding a restroomless bus may be tedious...?
If you buy from a dealer, they'll often remove the RR for a fee.  May be worth what they charge?
Jerry, you are going to need that restroom during your trip back to the Left Coast!  You found any co-pilots yet?   May I volunteer Kyle and Jon since they already have firsthand experience driving your bus!  ;)
Cheers, JR
JR Lynch , Charlotte, NC
Ayn Rand
