Jakey Brakey
Jakey Brakey
Started by Beatenbo, February 14, 2007, 08:56:35 PM
Beatenbo
How difficult and expensive to install a Jake brake on my mechanical 6V92T in a MCI 102C3. I sure would love to have one.
pvcces
It shouldn't be difficult as long as there is enough room for the tall valve covers or the risers. Some older vee drive buses require a hump to be built into the tailgate.
The price of the buffer switch, if you want to save your fast idle, may surprise you. I think it's much better if you install all of the parts right at the beginning, rather than waiting to put some of the switches and their wiring in.
A bad install can do engine damage, so get some experienced help.
Good luck.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Eagle
I had my Eagle 6V92TA done by Diesel Injection with a two stage system and the buffer switch for about $2500.00.  This included all parts and labor with the high valve covers not spacers.  New system.  You should be able to find a used unit for about $800.00 or less.
kbunnystarr
what is a buffer switch ?
You must be the change you wish to see in the world.
DrivingMissLazy
Kristine, I answered your question in the post above.
Quote from: kbunnystarr on February 15, 2007, 03:25:31 PM
