Aluminum wheels or stainless simulators?
Started by OKIE9ERS, October 09, 2018, 02:45:32 PM
jraynor
What size rims are you looking for? I know a source that has a bunch of 22.5" x 9.00" Alcoa Aluminum Wheels for $125 each. Im sure you can get a deal if you buy all that you need at once
Jonathan
1986 TMC 102A3 6V92TA Currently Under Reno
OKIE9ERS
Quote from: jraynor on October 18, 2018, 09:50:28 AM
22.5x 825 stud pilot
'81 MC-9 8V-71
4SPD DANA
The 9" are hub piloted I never saw one in a stud pilot I am not saying they never made one though
DoubleEagle
The stud piloted ones are getting harder to find, you might have to settle for ones that are less than ideal. The alternative, if you want aluminum badly, would be to change your hubs for the hub centering type, but that would be pricey, if possible.
Walter
Dayton, Ohio
On GM's, only need to change the studs. The hubs are the same. Check out the metric I'd of the hole in the hub piloted wheel...it converts to the same inch dimension of the stud piloted wheels. They list that hub piloted wheels were an option on GM models.
OKIE9ERS
Well fooey(edited)...
Turns out my 3/10" longer studs I found are exactly the same length as whats already on my bus--didnt know that until jacking it up and removing the wheel and drum...since I had it right there went ahead a tried that shiny new aluminum on those studs...
No good...only got about  half the nut on there....
So...put that ugly @$# steel back on there and resume my search for studs, that arent 20 bucks apiece...
It was nice practice getting that wheel off the ground and off...got to see alot of stuff behind there I hadnt seen yet...
'81 MC-9 8V-71
4SPD DANA
