Cranking voltage
Started by thomasinnv, May 30, 2018, 12:00:08 PM
Jim Eh.
Quote from: eagle19952 on June 01, 2018, 05:13:42 AM
I have bought DEKA AGM 1400 CCA  that came off the shelf testing 1600cca. I think those #'s are advertising...
or minimums from the legal department.
used topay 160$ for NAPA 8d's retail jobber was less....
I think the good old days are gone :(
Just wondering how you are testing the CCA?
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
Quote from: Jim Eh. on June 01, 2018, 08:52:34 AM
i didn't, the dealer did while I watched.
off the shelf.
with an analyzer the size of a small shopping wagon.
A DEKA distributor.
A carbon pile tester works the best for testing CCA
A few 1500 watt electric heaters connected together will work for the larger ones.
I was gonna say batts too. My 102 has this exact behavior as the one of the batts was dying. Glad you're all set Derrick
sledhead
Quote from: sledhead on May 30, 2018, 03:45:19 PM
my cat is a bitch to start . the first revolution always sounds like it will never start ( sloooow ) then it moves faster and its running . it has never not started yet but it does this every time when the engine is cold . when its warm it starts fine . this is with 4  x 31 cat batteries that are 26 months old . I do have a 400 amp boost switch so I can use the house batteries
 ( 660 amps ) to help . hope I never need to use it  but it is there if I need it
https://photos.app.goo.gl/eoEyiWEDbBYSPzEz2
https://photos.app.goo.gl/tK7h6kxNrrK4USmA2
https://photos.app.goo.gl/KfVyaqP8xbiYIAzz2
dave
update !
I removed and cleaned all battery connections and the connections at the starter . re taped the + on all the batteries  with red electrical tape
now it spins over way fast ever time .  wow ! only took 2 hours and should have done it a long time ago
dave
dave , karen
Dave5Cs
2,Napa 7236 1149 at  32 degrees and 950 at 0 degrees. I replace them at 5.5 years 117.00 no problems with them.
