NMF additive
Started by jraynor, August 04, 2018, 08:07:11 PM
jraynor
I've seen this on Facebook a few times and now that I have a good potential use for it, has anyone tried it before? They have buyers mentioning that engines and transmissions run cooler and they say that fuel efficiency can be improved by using it in the engine, trans and hubs. They say add an oz per quart of oil. So my 27 quart engine would take 27 ounces. Any opinions?
Jonathan
1986 TMC 102A3 6V92TA Currently Under Reno
Quote from: jraynor on August 04, 2018, 08:07:11 PMI've seen this on Facebook a few times and now that I have a good potential use for it, has anyone tried it before? They have buyers mentioning that engines and transmissions run cooler and they say that fuel efficiency can be improved by using it in the engine, trans and hubs. They say add an oz per quart of oil. So my 27 quart engine would take 27 ounces. Any opinions?
        No experience but it sure smells like snake oil to me.  I'm pretty sure that they found most of their website statements on the ground in a cattle feed lot.
I wouldn't use it all it is Chlorinated wax,it was around by another name in 70's during the oil crunch along with Slick 50 that contained Teflon
Junk
If it was so good, why wouldn't the big boys already have it built in to their lubes?
Never forget, the big boys are fiercely competitive and there's serious money at stake.
A busnut saves pennies per mile, a large truck fleet saves millions of dollars...
The lube company that finds this miracle will put the others out of business...
Back to boring stock lubes and fuels...
Happy coaching!
Buswarrior
kyle4501
Without detailed lab results from LONG TERM (over 5 years) testing, I wouldn't put it in anything (except proper waste disposal).
Far to many snake oil products out there that will improve performance short term, but reduce performance soon enough.
While some may not cause any real damage, some will definitely shorten the time interval to the next major overhaul.
Templar52
It look like Lucas heavy duty oil stabilaser????
Quote from: Templar52 on August 05, 2018, 07:16:59 AM
Snake oil by another name :) imo.
